Knowledge Base Article
What is the latest device firmware for the Quartus® Prime Pro Edition Software version 23.3?
Description
The latest device firmware for the Quartus® Prime Pro Edition Software version 23.3 can be downloaded from the following links.
Fixes for the following problems are included in the latest release (The newest release contains all prior fixes and supersedes earlier device firmware releases).
Change Log
Firmware version 0.06fw:
Integrate the latest comprehensive UX Hard IP firmware for improved F-Tile (General purpose Tile) functionality.
Firmware version 0.22fw:
This patch fixes the SDM mailbox voltage sensor readout issue which was exceeding device specification with VADC equations workaround, new fuse equation differentiator and raw value sampling improvement in Agilex™ devices.
The patch also includes fixes for the following bugs:
- SDI test passed is passing in certain Quartus® builds but failing some.
- F-Tile Dynamic Reconfiguration Design Fails to function when programmed with Quartus® Prime Pro Edition Software version 23.3, yet functions properly when programmed with Quartus® Prime Pro Edition Software version 23.2.
Please also see the following links:
Resolution
Download the latest Device Firmware below.
Note:
- Patches must be applied to the Quartus® Prime Pro Edition Software and the Quartus® Prime Pro Edition Software Programmer and Tools.
- Recompilation is not required.
- All programming files should be recreated.
- Re-run programming file generation or conversion using the Quartus® Prime Software programming file generator.
Updated 3 days ago
Version 4.0No CommentsBe the first to comment
