Knowledge Base Article
What is the latest device firmware for the Quartus® Prime Pro Edition Software version 23.4?
Description
The latest device firmware for the Quartus® Prime Pro Edition Software version 23.4 can be downloaded from the following links.
Fixes for the following problems are included in the latest release (The newest release contains all prior fixes and supersedes earlier device firmware releases).
Change Log
Firmware version 0.07fw:
This patch fixes the issue where non-PCIe and PCIe lanes are used on the same F-Tile bank, and PCIe PERST# is asserted prior to configuration, the non-PCIe transceivers will not properly come up. This patch decouples PCIe PERST# reset requirement from non-PCIe transceivers.
Please also see the following links:
- Updating the SDM Firmware in the Agilex™ FPGA Configuration User Guide
- Updating the SDM Firmware in the Stratix® 10 FPGA Configuration User Guide
Resolution
Download the latest device firmware from the following links.
- Patch 0.07FW for the Quartus® Prime Pro Edition Software for Windows (.exe)
- Patch 0.07FW for the Quartus® Prime Pro Edition Software for Linux (.run)
- Readme for Patch 0.07FW for the Quartus® Prime Pro Edition Software for Windows (.txt)
Note:
- Patches must be applied to the Quartus® Prime Pro Edition Software and the Quartus® Prime Pro Edition Software Programmer and Tools.
- Recompilation is not required.
- All programming files should be recreated.
- Re-run programming file generation or conversion using the Quartus® Prime Software programming file generator.
Updated 11 months ago
