Knowledge Base Article
What is the latest device firmware available for the Quartus® Prime Pro Edition Software version 20.3?
Description
The latest device firmware for the Quartus® Prime Pro Edition Software version 20.3 can be downloaded from the links below.
Fixes for the following problems are included in the latest release (The latest release includes all prior fixes and supersedes earlier device firmware releases):
Change log :
0.05fw
This fixes a problem with Stratix 10 Provisioning firmware, which was nonfunctional.
0.08fw
This fixes a problem that may result in Stratix 10 reconfiguration or partial reconfiguration issues when SEU is enabled.
0.34fw
This fixes a configuration error seen during JTAG configuration for Agilex™ FPGA devices
0.44fw
This fixes a configuration error on Stratix 10, which reports as Major error = 0xF004 & Minor error = 0x002d after reconfiguration.
0.48fw
The patch fixes spurious SEU error reported on unused CRAM spare row.
0.66fw
This patch is to fix the fault injection debugger coordinates issue for SEU
0.69fw
This is the firmware fix for the UIB timeout issue.
0.78fw
This fixes a problem that may cause Stratix 10 reconfiguration to hang when a corrupted RBF is loaded, causing a HPS watchdog malfunction.
0.81fw
This patch addresses the following problem - For Designs using Stratix 10 Remote System Update, Remote System Update may fall back to the Factory Slot if a Combined Application Image is corrupt.
Please also see the following user guides:
Resolution
Download the latest device firmware below.
Note:
  • Patches must be applied to the Quartus® Prime Pro Edition Software and the Quartus® Prime Pro Edition Software Standalone programmer.
  • Recompilation is not required.
  • All programming files should be recreated.
    • Re-run the programming file generation or conversion using the Quartus® Prime Software programming file generator.
Updated 8 months ago
Version 4.0
