Knowledge Base Article
What is the latest device firmware available for the Quartus® Prime Pro Edition Software version 22.4?
Description
The latest device firmware for the Quartus® Prime Pro Edition Software version 22.4 can be downloaded from the following links.
Fixes for the following problems are included in the latest release (The newest release contains all prior fixes and supersedes earlier device firmware releases).
Change Log
Firmware version 0.03fw:
  • Fix NW formatter tool to cover the override scenario where memories located in last bRAM column in the array are overwritten. The propagation configuration time was increased.
  • Firmware update to fix the issue where odd number of headers are not paged correctly when copied from via ROM into local buffer. Add dedicated case for odd number of headers.
Firmware version 0.06fw:
  • Stratix® 10 Remote System Update for SoC: Factory Update Images may fail with errors resulting in corrupt RSU CPB tables if the last slot of the CPB table is in use (unavailable) or if the Factory Update Image uses the top (last slot) of the CPB table.
  • Agilex™ FPGA: Intermittent failures may be seen when the HPS Cold Reset Pin is used in FPGA First boot mode in ASx4 configuration mode.
  • Agilex™ FPGA: Remote System Update may fail to recover after using an incorrect device application image.
Firmware version 0.21fw:
  • Fixes a bug in the Programming File Generator GUI - When the address for partition P1 was entered manually with the same value that the .map file for the automatically-generated file indicated, the .rpd files did not match.
Please also see the following:
Resolution
Download the latest Device Firmware from below.
Note:
  • Patches must be applied to the Quartus® Prime Pro Edition Software and the Quartus® Prime Pro Edition Software Programmer and Tools.
  • Re-compilation is not required.
  • All Programming files should be re-created.
    •   Re-run programming file generation or conversion using the Quartus® Programming File Generator.
Updated 8 months ago
Version 5.0
