Knowledge Base Article
What can cause my PCI Express bus to hang while transmitting?
Description
If you send a TLP with a payload size greater than the maximum supported system-level Max Payload Size the link will fail to operate.
You should qualify your TLPs with Max Payload Size in tl_cfg_ctl address 0, cfg_dev_ctrl[7:5], otherwise the link will fail to operate due to incorrect packet sizes.
A SignalTap®  capture with many assertions and de-assertions of tx_st_ready per TLP and no EOP is a symptom of this error.
Resolution
Ensure that both hardware and software are abiding by the PCI Express®  specification to only send TLPs up to the Max Payload Size or Max Read Request Size.
Updated 2 months ago
Version 2.0
