Knowledge Base Article
Quartus® Prime Pro Edition User Guide - Map file description not full in Table 3. Programming File Generator Output File Types
Description
The description for the Map file is in Table 3. Programming File Generator Output File Types of the Quartus® Prime Pro Edition User Guide: Programmer is not full.
User Guide: Quartus® Prime Pro Edition User Guide: Programmer
Version: 4/03/2023
Section: 2.2.1.2. Secondary Programming Files (Programming File Generator)
Table: Programming File Generator Output File Types
Resolution
Not full description is:
A text file containing the byte addresses of pages and data stored in the memory of a configuration device for
Full description should like below:
A text file containing the byte addresses of pages and HEX data stored in the memory of an EPC4, EPC8, or EPC16 configuration device. The file stores the start and end addresses of the Main Block Data and Bottom Boot Data items, and the start and end addresses of pages within the Main Block Data item.
This updated information will be added in the Intel® Quartus® Prime Pro Edition User Guide: Programmer, version 24.1.
Updated 8 months ago
Version 4.0
