Knowledge Base Article
Internal Error: Sub-system: RDB, File: /quartus/db/rdb/rdb_utility.cpp, Line: 1944 rval == nullptr
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 25.3.1 and earlier, you might see this internal error when performing an IP Upgrade.
Resolution
To work around this problem, delete the qdb folder before compiling the project.
The problem has been fixed starting with Quartus® Prime Pro Edition software version 26.1.
Updated 3 months ago
Version 5.0No CommentsBe the first to comment
