Knowledge Base Article
Error: VHDL error at auk_dspip_roundsat_hpfir.vhd(103): value "4294967295" is outside the target constraint range (-2147483848 to 2147483647)
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition software version 19.2, the error above can be seen when the output width of the FIR II Intel® FPGA IP is greater than or equal to 32 bits in rounding mode.
Resolution
To work around this error in existing software, set the IP parameter "Output LSB Rounding" to "Truncation", or still use "Rounding", but ensure that the output width is smaller than 32 bits.
This problem has been fixed starting with the Intel® Quartus® Prime Pro Edition software version 20.1.
Updated 1 month ago
