Knowledge Base Article
Error: no such variable (read trace on "::env(IP_ROOTDIR)") invoked from within "return "$::env(IP_ROOTDIR)/altera/emif/ip_arch_nd/fw_src""
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 21.1 for Linux* or Windows* operating systems,  you may see an error message similar to the following when generating the EMIF or PHYLite IP for the Stratix® 10 or the Agilex™ 7 devices:
    invoked from within
    (procedure "get_iossm_firmware_source_dir" line 3)
    invoked from within"get_iossm_firmware_source_dir 1"
    (procedure "get_sim_cal_code_hex_src_filename" line 2)
    invoked from within    "get_sim_cal_code_hex_src_filename $force_firmware"
    (procedure "_generate_common_fileset" line 36)       invoked from within
Resolution
To work around this problem, ensure the Linux* or Windows* environment variable "IP_ROOTDIR" is set to the ip sub-directory in the Quartus® Prime Pro Edition Software installation.
An example for the Windows* version is: IP_ROOTDIR = C:\intelFPGApro\21.1\ip
This problem is fixed starting with the  Quartus® Prime Pro Edition Software version 21.2.
Updated 11 months ago
Version 3.0
