Knowledge Base Article
Does the DisplayPort Intel® FPGA IP support DisplayPort Dual-Mode (DP)?
Description
No, the DisplayPort Intel® FPGA IP does not support DisplayPort Dual-Mode (DP).
Resolution
Dual-Mode DisplayPort allows High Definition Multimedia Interface (HDMI) or Digital Visual Interface (DVI) to be sent through the DisplayPort electrical connector with the pin functions being re-mapped.
A DP capable display is fully compatible with the DisplayPort Intel® FPGA IP.
The HDMI Intel® FPGA IP which supports DVI should be used in place of the DisplayPort Intel® FPGA IP if either of these standard need to be sent through the DisplayPort connector.
Updated 3 months ago
Version 3.0
