Knowledge Base Article
Can I use ASMI Parallel Intel® FPGA IP Core to perform the “Read Silicon ID” operation (read_sid) for EPCQA device?
Description
No, the ASMI Parallel Intel® FPGA IP Core cannot perform the “Read Silicon ID” operation for EPCQA devices. The option “Use ‘read_sid’ port” is gray out in the ASMI Parallel IP core parameter when using EPCQA device.
However, the ASMI Parallel Intel FPGA IP can perform the “Read Device IP” operation for the EPCQA device.
Resolution
There is no workaround.
Updated 2 months ago
