Knowledge Base Article
Are there any known issues with the transceiver Tx signal integrity that may increase the BER on Stratix® V GX production silicon devices?
Description
Yes, due to a bug in Quartus® II software versions 12.0, 12.0SP1, and 12.0SP2, you may see a periodic glitch on the transceiver Tx pins of Stratix® V GX production devices.
The glitch will produce a marginal increase in Tx jitter which may result in a marginally higher Bit Error Rate (BER).
Resolution
To fix this problem, install the appropriate patch below.
Patches for Quartus® II software version 12.0 dp2
Patches for Quartus® II software version 12.0 dp3
Patches for Quartus® II software version 12.0 SP1
Patches for Quartus® II software version 12.0 SP2
After installing the patch, regenerate your transceiver PHY and/or QSYS system and recompile your project.
Updated 4 months ago
Version 4.0
