Knowledge Base Article
* Error: Module parameter 'CFG_CMD_GEN_OUTPUT_REG' not found for override at alt_mem_ddrx_controller.v
Description
You might see the above error when simulating your DDR3 UniPHY controller with the ModelSim-Intel® FPGA. The cause of the error is the ordering of the compilation libraries in the ModelSim vsim elaboration call.
Resolution
You must make sure the library containing the DDR3 compiled files is listed first in the command. In this case, the work directory contains the DDR3 compiled files:
vsim -novopt -t ps -L work -L altera_ver -L lpm_ver -L sgate_ver -L altera_mf_ver -L altera_lnsim_ver -L altera_mf -L altera_lnsim -L stratixiv <top_level_filename>
It is recommended that you follow the file and library ordering in the msim_setup.tcl file provided in the <IP_variation_name>_sim/mentor directory.
Updated 3 months ago
Version 2.0
