14 years agoWORKING: DE2-115 Simple Socket Server
It seems difficult to get help on these forums so I want to pass on what i learnt for others. I've struggled to learn FPGAs over the past few weeks and I have finally got a simple socket server working for the DE2-115. I'll quickly post my findings so someone else can take this and learn from it and not have to struggle on their own as i did. procedure I'll make this brief:- I used updated versions for everything as of 4/4/11. 10.1 Sp1.
- Download and install the Knowledge base update to prevent nios from crashing. http://www.altera.com/support/kdb/solutions/rd12222010_317.html
- Take the Quartus DE2_115 webserver example for Enet0 RGMII that comes on the CD and use quartus flash programmer to program.
- Get this PDF and follow its instructions "http://www.altera.com/literature/tt/tt_nios2_tcpip.pdf?gsa_pos=1&wt.oss_r=1&wt.oss=simple socket server example nios edition socket server example nios edition" NOTE it includes the spaces (wierd). do everything the same except the part mentioned in my next step.
- Instead of copying the files from the tutorial.zip; copy the ones that i have attached to this post. (the .c and .h files including the eeprom folder)
- This example will now work as explained in the pdf.
- The original example code in the tutorial does not have the correct method for gettig the MAC address on the DE2-115. I have deleted the majority of the original MAC code and replaced it with code i got from the DE2-115 webserver example. This includes the flashgetoffset function.
- The LED_PIO_BASE in the original is an invalid for the DE2-115. I replaced it with the LEDG (green leds), you could replace it with red if you wished. This has been done by modifying the led.c file.
