15 years agoWORKING: DE2-115 Simple Socket Server
Hi, It seems difficult to get help on these forums so I want to pass on what i learnt for others. I've struggled to learn FPGAs over the past few weeks and I have finally got a simple socket s...
15 years ago --- Quote Start --- Do you have other error messages in the console, such as a verify fail? Did you run a memory test program on the SRAM? --- Quote End --- After that the download is completed (it gets 100%) i have a window saying "Hardware configuration' has encountered a problem. Downloading ELF Process failed" but in the warnings tab are two errors: Error launching external scanner info generator (sh -c 'g++ -E -P -v -dD C:/Users/Anónimo/workspace/.metadata/.plugins/org.eclipse.cdt.make.core/specs.cpp ') Error launching external scanner info generator (sh -c 'gcc -E -P -v -dD C:/Users/Anónimo/workspace/.metadata/.plugins/org.eclipse.cdt.make.core/specs.c ') both files, specs.cpp and specs.c, seem empty i didnt run a memory test program on the SRAM. i dont know how i can do it. could you show a example? thanks
