15 years agoWORKING: DE2-115 Simple Socket Server
Hi, It seems difficult to get help on these forums so I want to pass on what i learnt for others. I've struggled to learn FPGAs over the past few weeks and I have finally got a simple socket s...
15 years ago --- Quote Start --- "Hardware configuration' has encountered a problem. Downloading ELF Process failed" --- Quote End --- Hi PeFarina, Another thing to check is that the folder for your software project has sharing permissions. Part of the process of downloading the ELF file involves changing file attributes which cannot be accomplished if Eclipse does not have sharing privileges with the project folder. On my Windows 7 system I right-click on the project folder and select Share with > Homegroup (Read/Write). Your procedure may vary slightly depending on your system. Good luck!
