16 years agoUp/down counter Quartus II UP2 board
Hi guys!!!
i'm new in altera forum, and in vhdl too. i must to do this project in Quartus II with the support of UP 2 board: design an up/down decimal counter that: 1. show the count in a two 7 segment display in the UP2 board; 2. we can select the initial number of the count by switchs; 3. pushing the button present in UP2 board the counter must invert the count. Someone can help me??? I Thanks you advance..:D4 Replies
Why don't you show us what you wrote until now so that we can give you some advice?
Use counter from LPM library. It has most of the functionality you ask for. You need to code a HEX-to-7-segment active low decoder.
before to show my vhdl code i thanks you for reply me :))))
this is my work until now: library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; ENTITY counter IS PORT( clk : in BIT; upordwn : in STD_LOGIC; initial : in STD_LOGIC_VECTOR(7 DOWNTO 0); count : OUT STD_LOGIC_VECTOR(7 DOWNTO 0); LED_1 : OUT STD_LOGIC_VECTOR(7 DOWNTO 0); LED_2 : OUT STD_LOGIC_VECTOR(7 DOWNTO 0); LED_CENT : OUT STD_LOGIC_VECTOR(7 DOWNTO 0)); end counter; ARCHITECTURE prova OF counter IS SIGNAL totalbit : STD_LOGIC_VECTOR(7 DOWNTO 0); SIGNAL up_four : STD_LOGIC_VECTOR(4 DOWNTO 0); SIGNAL low_four : STD_LOGIC_VECTOR(4 DOWNTO 0); BEGIN PROCESS(clk) --QUI DEVO INSERIRE IL VALORE INIZIALE if(clk'EVENT AND clk='1') THEN if (upordwn='1') THEN totalbit <= totalbit+1; else totalbit <= totalbit-1; end if; end if; END PROCESS; low_four(0) <= totalbit(0); low_four(1) <= totalbit(1); low_four(2) <= totalbit(2); low_four(3) <= totalbit(3); up_four(0) <= totalbit(4); up_four(1) <= totalbit(5); up_four(2) <= totalbit(6); up_four(3) <= totalbit(7); WITH up_four SELECT --abcdefg LED_1 <= "00000011" WHEN "1111", -- 0 "10011111" WHEN "1110", -- 1 "00100101" WHEN "1101", -- 2 "00001101" WHEN "1100", -- 3 "10011001" WHEN "1011", -- 4 "01001001" WHEN "1010", -- 5 "01000001" WHEN "1001", -- 6 "00011111" WHEN "1000", -- 7 "00000001" WHEN "0111", -- 8 "00001001" WHEN "0110", -- 9 "00010001" WHEN "0101", -- A "00000001" WHEN "0100", -- B "01100011" WHEN "0011", -- C "00000011" WHEN "0010", -- D "01100001" WHEN "0001", -- E "01110001" WHEN "0000", -- F "00000011" WHEN OTHERS; --Lower 4 bits WITH low_four SELECT --abcdefg LED_2 <= "00000011" WHEN "1111", -- 0 "10011111" WHEN "1110", -- 1 "00100101" WHEN "1101", -- 2 "00001101" WHEN "1100", -- 3 "10011001" WHEN "1011", -- 4 "01001001" WHEN "1010", -- 5 "01000001" WHEN "1001", -- 6 "00011111" WHEN "1000", -- 7 "00000001" WHEN "0111", -- 8 "00001001" WHEN "0110", -- 9 "00010001" WHEN "0101", -- A "00000001" WHEN "0100", -- B "01100011" WHEN "0011", -- C "00000011" WHEN "0010", -- D "01100001" WHEN "0001", -- E "01110001" WHEN "0000", -- F "00000011" WHEN OTHERS; count <= totalbit; end prova; I have two problems yet! 1. initialing a strart number for the count by 8 switches present in UP2 board; 2. show the result in decimal (not in hexadecimal format) in the 7segment display. thanks again :D - Altera_Forum
You could include a reset signal input that would load the value from the initial input to the totalbits value.
You can design your process this way:
To change from hexadecimal to decimal you can use the arithmetic library and divisions by 10.PROCESS (clk,reset) IF (reset='1') THEN -- initialization of signals and outputs ELSIF (clk'EVENT AND clk='1') THEN -- counting END IF; END PROCESS;
