16 years agoUp/down counter Quartus II UP2 board
Hi guys!!! i'm new in altera forum, and in vhdl too. i must to do this project in Quartus II with the support of UP 2 board: design an up/down decimal counter that: 1. show the count in ...
16 years agobefore to show my vhdl code i thanks you for reply me :))))
this is my work until now: library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; ENTITY counter IS PORT( clk : in BIT; upordwn : in STD_LOGIC; initial : in STD_LOGIC_VECTOR(7 DOWNTO 0); count : OUT STD_LOGIC_VECTOR(7 DOWNTO 0); LED_1 : OUT STD_LOGIC_VECTOR(7 DOWNTO 0); LED_2 : OUT STD_LOGIC_VECTOR(7 DOWNTO 0); LED_CENT : OUT STD_LOGIC_VECTOR(7 DOWNTO 0)); end counter; ARCHITECTURE prova OF counter IS SIGNAL totalbit : STD_LOGIC_VECTOR(7 DOWNTO 0); SIGNAL up_four : STD_LOGIC_VECTOR(4 DOWNTO 0); SIGNAL low_four : STD_LOGIC_VECTOR(4 DOWNTO 0); BEGIN PROCESS(clk) --QUI DEVO INSERIRE IL VALORE INIZIALE if(clk'EVENT AND clk='1') THEN if (upordwn='1') THEN totalbit <= totalbit+1; else totalbit <= totalbit-1; end if; end if; END PROCESS; low_four(0) <= totalbit(0); low_four(1) <= totalbit(1); low_four(2) <= totalbit(2); low_four(3) <= totalbit(3); up_four(0) <= totalbit(4); up_four(1) <= totalbit(5); up_four(2) <= totalbit(6); up_four(3) <= totalbit(7); WITH up_four SELECT --abcdefg LED_1 <= "00000011" WHEN "1111", -- 0 "10011111" WHEN "1110", -- 1 "00100101" WHEN "1101", -- 2 "00001101" WHEN "1100", -- 3 "10011001" WHEN "1011", -- 4 "01001001" WHEN "1010", -- 5 "01000001" WHEN "1001", -- 6 "00011111" WHEN "1000", -- 7 "00000001" WHEN "0111", -- 8 "00001001" WHEN "0110", -- 9 "00010001" WHEN "0101", -- A "00000001" WHEN "0100", -- B "01100011" WHEN "0011", -- C "00000011" WHEN "0010", -- D "01100001" WHEN "0001", -- E "01110001" WHEN "0000", -- F "00000011" WHEN OTHERS; --Lower 4 bits WITH low_four SELECT --abcdefg LED_2 <= "00000011" WHEN "1111", -- 0 "10011111" WHEN "1110", -- 1 "00100101" WHEN "1101", -- 2 "00001101" WHEN "1100", -- 3 "10011001" WHEN "1011", -- 4 "01001001" WHEN "1010", -- 5 "01000001" WHEN "1001", -- 6 "00011111" WHEN "1000", -- 7 "00000001" WHEN "0111", -- 8 "00001001" WHEN "0110", -- 9 "00010001" WHEN "0101", -- A "00000001" WHEN "0100", -- B "01100011" WHEN "0011", -- C "00000011" WHEN "0010", -- D "01100001" WHEN "0001", -- E "01110001" WHEN "0000", -- F "00000011" WHEN OTHERS; count <= totalbit; end prova; I have two problems yet! 1. initialing a strart number for the count by 8 switches present in UP2 board; 2. show the result in decimal (not in hexadecimal format) in the 7segment display. thanks again :D
