16 years agoUp/down counter Quartus II UP2 board
Hi guys!!! i'm new in altera forum, and in vhdl too. i must to do this project in Quartus II with the support of UP 2 board: design an up/down decimal counter that: 1. show the count in ...
16 years agoYou could include a reset signal input that would load the value from the initial input to the totalbits value.
You can design your process this way:PROCESS (clk,reset)
IF (reset='1') THEN
-- initialization of signals and outputs
ELSIF (clk'EVENT AND clk='1') THEN
-- counting
END IF;
END PROCESS; To change from hexadecimal to decimal you can use the arithmetic library and divisions by 10.
