Nonexistent "Nios II Hardware" Debug Config
When I go to debug my assembly application to write it to my DE2 board (using confirmed proper .sopcinfo and .sof files), there is no "Nios II Hardware" debug configuration. I attached a screenshot to show what I'm talking about.
So, has anyone else run into this problem and know how to fix it? Thanks!6 Replies
Yup D0M1NIX, I am seeing this very thing and am trying to find a solution. I am running an older version of Quartus and the Nios II SDK for Eclipse, 9.1sp2, on an unsupported OS for that version--Windows 7. I did not have this problem until the lab computer got switched from XP and I'm wondering if that is related.
-Brad - Altera_Forum
So, it's been 3 weeks, the thread has almost 1300 views, and no one has any clue to what's going on?
Just as an FYI to everyone reading this, I have tried literally everything I could think of to this very point in time.
I even tried using my board on my lab computer at school, and it comes up with the "Nios II Hardware" debug configuration. This has me beat. - Altera_Forum
This is beyond upsetting. I opened a new ticket under mySupport Oct. 29, took 3 or so days to respond, they asked a few questions about the issues with the board, and they ended up telling me to email [email protected]...
THEY HAVE NOT RESPONDED THUS FAR, AND IT'S BEEN 3 FULL DAYS!!! I have not been able to use my board since I received it a month ago. In addition to the debugger problem I'm having, the .sopcinfo and .sof files I was provided on one of the CD's that came with the board are NOT compatible with my board. Also, it seems like no one here on the forums knows a possible solution here. Am I really alone on this issue??? SMH x1000000!!!!!! - Altera_Forum
--- Quote Start --- This is beyond upsetting. I opened a new ticket under mySupport Oct. 29, took 3 or so days to respond, they asked a few questions about the issues with the board, and they ended up telling me to email [email protected]... THEY HAVE NOT RESPONDED THUS FAR, AND IT'S BEEN 3 FULL DAYS!!! I have not been able to use my board since I received it a month ago. In addition to the debugger problem I'm having, the .sopcinfo and .sof files I was provided on one of the CD's that came with the board are NOT compatible with my board. Also, it seems like no one here on the forums knows a possible solution here. Am I really alone on this issue??? SMH x1000000!!!!!! --- Quote End --- I don't think 3 days is necessarily a terribly long time for input on a subtle, insidious issue like this, but it is confusing. I got some tips from tech support as follows, though none of them appeared to work for me. Altera was as usual very friendly and professional and offered additional help if I end up needing it. I have temporarily worked around this problem by running Quartus 9.1 on a Windows XP PC. For what it's worth, here is the advice I got (tech's name removed to not throw them back under the bus on this one): ---- Hi Brad, This is <tech name> with Altera embedded applications. One thing that could have happened is that Eclipse has defaulted to the "C/C++" perspective instead of the "Nios II" or "Nios II Debug" perspective. This would cause only the "Local C/C++ Application" to show under "Run as..." or "Debug as...". Can you try the following under the Eclipse GUI (once it is brought up):- Click on the "Window -> Open Perspective" menu item at the top menu bar
- Click on "Nios II". You may need to select "Other..." first if the "Nios II" perspective does not appear.
- Click on the Windows "start" menu and select "Altera 9.1* -> Nios II EDS * -> Nios II 9.1 Command Shell"
- From the command shell prompt, run "eclipse-nios2 -clean"
- Edit your eclipse.ini file to add the following "-Dosgi" line to the bottom after the -vmargs link. The eclipse.ini file can be found here: C:\altera\<version>\nios2eds\bin\eclipse_nios2\eclipse.ini
The University Program tech support people have not responded since I sent the first email to them. I sent another email to them a couple days ago and still no response.
I tried all of those possible solutions, but to no avail.
