LVDS-Rx IP (DE10 SoC-Cyclone V) interfacing with external ADC : Error in compilation & clock routing
We're using a ALTERA Cyclone V DE10-SoC board and need to interface FPGA “altlvds_rx” IP with an external ADC's LVDS outputs (data, high speed clock, low speed clock).
We have tried directly connecting the FPGA pins (LVDS pair) to the “altlvds_rx” IP (Pin: “rx_in”, “rx_inclock”, “rx_enable”) for this purpose.
Issues:
1. When I instantiate “altlvds_rx” with Data and clock pins (Pin: “rx_in”, “rx_inclock”, “rx_enable”)
as the top module pins, and tried to compile, In Analysis & Synthesis step it showed:
• “WRITECLK” and “LOADEN” not properly connected.
Request:
• How can we correctly interface external ADC’s LVDS signals (data, high speed clock, low speed clock) to “altlvds_rx” via FPGA pins ?
• Any peripheral IP should be connected between Top pins (FPGA LVDS pair) and “altlvds_rx” pins (“rx_inclock”, “rx_enable”) to get rid of compilation error and also have successful routing ?
• Example designs or suggestions to resolve these errors and successfully interface FPGA “altlvds_rx” IP with external LVDS ADC outputs ?
Any guidance would be greatly appreciated.
- FvM
generally, it would be helpful to get a complete problem specification:
- Quartus version
- SERDES configuration details
- intended RX clocking method
You have apparently set SERDES RX module to external PLL operation without connecting a PLL (won't be possible for a top level module). That doesn't make much sense because you most likely don't have fast and slow clocks (inclock and rx_enable) with appropriate timing. - WZ2
Hi there,
- For this IP, the example design can typically be generated by selecting the "Generate Example Design" option in the IP parameter editor. You may try generating it under a Cyclone 10 or Arria 10 device — the IP itself is the same across these devices.
- Regarding the three pins you asked about, their connection method largely depends on your specific IP configuration. Based on your question, I assume you're trying to use an external PLL? Without knowing the exact IP settings, I can only make some general assumptions. The Clock input should be connected to a pin that supports clk_in functionality — please refer to the device's pin list to ensure compatibility.
Let me know if you can share more about your configuration — I’d be happy to provide more specific suggestions.
WZ
