santosh2uu2
1 year agoLVDS-Rx IP (DE10 SoC-Cyclone V) interfacing with external ADC : Error in compilation & clock routing
We're using a ALTERA Cyclone V DE10-SoC board and need to interface FPGA “altlvds_rx” IP with an external ADC's LVDS outputs (data, high speed clock, low speed clock). We have tried directly connect...
FvM
1 year agoHi,
generally, it would be helpful to get a complete problem specification:
- Quartus version
- SERDES configuration details
- intended RX clocking method
You have apparently set SERDES RX module to external PLL operation without connecting a PLL (won't be possible for a top level module). That doesn't make much sense because you most likely don't have fast and slow clocks (inclock and rx_enable) with appropriate timing.
- Quartus version
