Issues with Sending Data to Microcontroller via SPI Using DE10-Lite Board
Hi Everyone
I am using Intel DE10 lite M50DAF484C7G from this i am trying to communicate with microcontroller just a basic communication sending some random data but its not sending any data so in that i am using Arduino pins for spi pins can i have just a basic code for simple spi master and arduino pins i am using are correct or should i use other pins
@de10 @fpga
- paveetirrasrie_Altera
We don't provide code support for 3rd party tool but I believe you may grab the code in Arduino website.
Pavee
- FvM
some issues with the code- bit_cnt == 8 (else condition) does never happen, need reg [3:0] bit_cnt;
- data_reg is only loaded once on POR, spi_master sends mosi == 0 constantly after first frame
- using always @(posedge sclk) is legal but might cause timing issues in a complexer design. Better use single system clock and modify
clock-enable scheme respectively
What's the indended SPI mode?
Frank - paveetirrasrie_Altera
We didn't hear from you since last update. If you have a new question, feel free to open a new thread to get the support from Altera experts.
Thank you.
