12 years ago
FPGA - PC communication
Hey all, I am trying to get my DE2-115 board and my pc to communicate, but I have no idea where to even start. So far my FPGA training begins and ends with the 10 labs that came with the DE board, plus a few projects I did for fun. So, I have two questions:
1. Given that I have no knowledge of communication protocols and such, would it be easiest for me to learn and implement USB, Ethernet, or RS232?
2. Based on your answer to the first, can you please suggest some learning resources I could consult?
Much Appreciated
    RS232 is by far the easiest to implement. Many products still include RS232 as it is easy and cheap to implement on the FPGA and works with little debugging. Ethernet and USB are both massively complex. You cannot find USB or Ethernet cores for free.
    There are plenty of RS232 examples if you use google. Here is the first: http://www.fpga4fun.com/serialinterface.html
    Very few of the current PCs have an RS-232 port, but USB to RS-232 adapters are available.
    Hey just try my code - I have programmed the RS232 successfully today:
    //****** PAVLE DUKANOVIC *******
    //****** www.dukelanovic.com *******
    //****** [email protected] *******
    // Serial port demo program
    // http://www.techques.com/question/4-13718/implement-serial-port-on-fpga-(verilog)
    // Assumptions: 50Mhz clock rate
    module serial(input clk,input key_in, output ser, input rxd);
    // Start signal tells it to start sending bits
    reg[24:0]count;
    reg [3:0] ones;
    reg [3:0] tens;
    //The bits of data to send
    reg [7:0] data;
    reg sec;
    reg [14:0] clockdiv;
    reg [14:0] clockdivrx;
    // Output register to pin
    assign ser = outbit;
    // Count from 0..5207 then reset back to zero (9600 Baud for TX)
    always @(posedge clk)
    begin
    if (clockdiv == 5207)
    clockdiv <= 0;
    else
    clockdiv <= clockdiv + 1;
    end
    begin
    if (clockdivrx == 1302)
    clockdivrx <= 0;
    else
    clockdivrx <= clockdivrx + 1;
    end
    // The serclock is a short pulse each time we are reset
    wire serclock = (clockdiv == 0);
    wire start = (clockdiv == 0);
    wire serclockrx = (clockdivrx == 0);
    // Serial port state machine
    // Only start the state machine when "start" is set. Only advance to the
    // next state when serclock is set.
    reg [3:0] state;
    begin
    case (state)
    4'b0000: if (start) state <= 4'b0001;
    4'b0001: if (serclock) state <= 4'b0010; // Start bit
    4'b0010: if (serclock) state <= 4'b0011; // Bit 0
    4'b0011: if (serclock) state <= 4'b0100; // Bit 1
    4'b0100: if (serclock) state <= 4'b0101; // Bit 2
    4'b0101: if (serclock) state <= 4'b0110; // Bit 3
    4'b0110: if (serclock) state <= 4'b0111; // Bit 4
    4'b0111: if (serclock) state <= 4'b1000; // Bit 5
    4'b1000: if (serclock) state <= 4'b1001; // Bit 6
    4'b1001: if (serclock) state <= 4'b1010; // Bit 7
    4'b1010: if (serclock) state <= 4'b0000; // Stop bit
    default: state <= 4'b0000; // Undefined, skip to stop
    endcase
    end
    // Serial port data
    // Ensure that the serial port has the correct data on it in each state
    reg outbit;
    begin
    case (state)
    4'b0000: outbit <= 1; // idle
    4'b0001: outbit <= 0; // Start bit
    4'b0010: outbit <= data[0]; // Bit 0
    4'b0011: outbit <= data[1]; // Bit 1
    4'b0100: outbit <= data[2]; // Bit 2
    4'b0101: outbit <= data[3]; // Bit 3
    4'b0110: outbit <= data[4]; // Bit 4
    4'b0111: outbit <= data[5]; // Bit 5
    4'b1000: outbit <= data[6]; // Bit 6
    4'b1001: outbit <= data[7]; // Bit 7
    4'b1010: outbit <= 0; // Stop bit
    default: outbit <= 1;df // Bad state output idle
    endcase
    end
    reg [7:0] charstate;
    reg [5:0] rxstate;
    begin
    case (rxstate)
    6'b000000: if (!rxd) rxstate <= 4'b000001;
    6'b000001: if (serclockrx) rxstate <= 6'b000010;
    6'b000010: if (serclockrx) rxstate <= 6'b000011;
    6'b000011: if (serclockrx) rxstate <= 6'b000100;
    6'b000100: if (serclockrx) rxstate <= 6'b000101;
    6'b000101: if (serclockrx) rxstate <= 6'b000110;
    6'b000110: if (serclockrx) begin rxstate <= 6'b000111; data[0] <= rxd; end // The sixth tact LSB reg [7:0] data;
    6'b000111: if (serclockrx) rxstate <= 6'b001000;
    6'b001000: if (serclockrx) rxstate <= 6'b001001;
    6'b001001: if (serclockrx) rxstate <= 6'b001010;
    6'b001010: if (serclockrx) begin rxstate <= 6'b001011; data[1] <= rxd; end // The 10'th tact
    6'b001011: if (serclockrx) rxstate <= 6'b001100;
    6'b001100: if (serclockrx) rxstate <= 6'b001101;
    6'b001101: if (serclockrx) rxstate <= 6'b001110;
    6'b001110: if (serclockrx) begin rxstate <= 6'b001111; data[2] <= rxd; end // The 14'th tact
    6'b001111: if (serclockrx) rxstate <= 6'b010000;
    6'b010000: if (serclockrx) rxstate <= 6'b010001;
    6'b010001: if (serclockrx) rxstate <= 6'b010010;
    6'b010010: if (serclockrx) begin rxstate <= 6'b010011; data[3] <= rxd; end // The 18'th tact
    6'b010011: if (serclockrx) rxstate <= 6'b010100;
    6'b010100: if (serclockrx) rxstate <= 6'b010101;
    6'b010101: if (serclockrx) rxstate <= 6'b010110;
    6'b010110: if (serclockrx) begin rxstate <= 6'b010111; data[4] <= rxd; end // The 22'nd tact
    6'b010111: if (serclockrx) rxstate <= 6'b011000;
    6'b011000: if (serclockrx) rxstate <= 6'b011001;
    6'b011001: if (serclockrx) rxstate <= 6'b011010;
    6'b011010: if (serclockrx) begin rxstate <= 6'b011011; data[5] <= rxd; end // The 26'th tact
    6'b011011: if (serclockrx) rxstate <= 6'b011100;
    6'b011100: if (serclockrx) rxstate <= 6'b011101;
    6'b011101: if (serclockrx) rxstate <= 6'b011110;
    6'b011110: if (serclockrx) begin rxstate <= 6'b011111; data[6] <= rxd; end // The 30'th tact
    6'b011111: if (serclockrx) rxstate <= 6'b100000;
    6'b100000: if (serclockrx) rxstate <= 6'b100001;
    6'b100001: if (serclockrx) rxstate <= 6'b100010;
    6'b100010: if (serclockrx) begin rxstate <= 6'b100011; data[7] <= rxd; end // The 34'th tact
    6'b100011: if (serclockrx) rxstate <= 6'b100100;
    6'b100100: if (serclockrx) rxstate <= 6'b100101;
    6'b100101: if (serclockrx) rxstate <= 6'b100110;
    default: rxstate <= 6'b000000;
    endcase
    end
    endmodule
    There only one problem remained in the whole story - as I have been pressing a key in Putty.exe the module always was sending
    characters. So is here somebody who could give me a hint how I could program the whole story so that the module sends back only
    one character?
    --- Quote Start ---
    //****** www.dukelanovic.com (http://www.dukelanovic.com) *******
    reg[24:0]count;
    reg [3:0] ones;
    reg [3:0] tens;
    reg [7:0] data;
    reg sec;
    begin
    clockdiv <= 0;
    else
    end
    begin
    clockdivrx <= 0;
    else
    end
    reg [3:0] state;
    begin
    case (state)
    endcase
    end
    // Serial port data
    reg outbit;
    begin
    case (state)
    endcase
    end
    reg [5:0] rxstate;
    begin
    case (rxstate)
    endcase
    end
    endmodule
    one character?
    --- Quote End ---
    Your stop bit is 0. Needs to be 1.
