12 years agoFPGA - PC communication
Hey all, I am trying to get my DE2-115 board and my pc to communicate, but I have no idea where to even start. So far my FPGA training begins and ends with the 10 labs that came with the DE board, pl...
11 years ago --- Quote Start --- Hey just try my code - I have programmed the RS232 successfully today: //******************************************************* //****** PAVLE DUKANOVIC ******* //****** www.dukelanovic.com (http://www.dukelanovic.com) ******* //****** [email protected] ******* //******************************************************* // Serial port demo program // http://www.techques.com/question/4-13718/implement-serial-port-on-fpga-(verilog) // Assumptions: 50Mhz clock rate module serial(input clk,input key_in, output ser, input rxd); // Start signal tells it to start sending bits reg[24:0]count; reg [3:0] ones; reg [3:0] tens; //The bits of data to send reg [7:0] data; reg sec; reg [14:0] clockdiv; reg [14:0] clockdivrx; // Output register to pin assign ser = outbit; // Count from 0..5207 then reset back to zero (9600 Baud for TX) always @(posedge clk) begin if (clockdiv == 5207) clockdiv <= 0; else clockdiv <= clockdiv + 1; end // Count from 0..5207 then reset back to zero (9600 Baud for TX) always @(posedge clk) begin if (clockdivrx == 1302) clockdivrx <= 0; else clockdivrx <= clockdivrx + 1; end // The serclock is a short pulse each time we are reset wire serclock = (clockdiv == 0); wire start = (clockdiv == 0); wire serclockrx = (clockdivrx == 0); ///////////////////////////////////////////////////////////////////////////// // Serial port state machine // Only start the state machine when "start" is set. Only advance to the // next state when serclock is set. reg [3:0] state; always @(posedge clk) begin case (state) 4'b0000: if (start) state <= 4'b0001; 4'b0001: if (serclock) state <= 4'b0010; // Start bit 4'b0010: if (serclock) state <= 4'b0011; // Bit 0 4'b0011: if (serclock) state <= 4'b0100; // Bit 1 4'b0100: if (serclock) state <= 4'b0101; // Bit 2 4'b0101: if (serclock) state <= 4'b0110; // Bit 3 4'b0110: if (serclock) state <= 4'b0111; // Bit 4 4'b0111: if (serclock) state <= 4'b1000; // Bit 5 4'b1000: if (serclock) state <= 4'b1001; // Bit 6 4'b1001: if (serclock) state <= 4'b1010; // Bit 7 4'b1010: if (serclock) state <= 4'b0000; // Stop bit default: state <= 4'b0000; // Undefined, skip to stop endcase end /////////////////////////////////////////////////////////////////////////////// // Serial port data // Ensure that the serial port has the correct data on it in each state reg outbit; always @(posedge clk) begin case (state) 4'b0000: outbit <= 1; // idle 4'b0001: outbit <= 0; // Start bit 4'b0010: outbit <= data[0]; // Bit 0 4'b0011: outbit <= data[1]; // Bit 1 4'b0100: outbit <= data[2]; // Bit 2 4'b0101: outbit <= data[3]; // Bit 3 4'b0110: outbit <= data[4]; // Bit 4 4'b0111: outbit <= data[5]; // Bit 5 4'b1000: outbit <= data[6]; // Bit 6 4'b1001: outbit <= data[7]; // Bit 7 4'b1010: outbit <= 0; // Stop bit default: outbit <= 1;df // Bad state output idle endcase end reg [7:0] charstate; reg [5:0] rxstate; always @(posedge clk) begin case (rxstate) 6'b000000: if (!rxd) rxstate <= 4'b000001; 6'b000001: if (serclockrx) rxstate <= 6'b000010; 6'b000010: if (serclockrx) rxstate <= 6'b000011; 6'b000011: if (serclockrx) rxstate <= 6'b000100; 6'b000100: if (serclockrx) rxstate <= 6'b000101; 6'b000101: if (serclockrx) rxstate <= 6'b000110; 6'b000110: if (serclockrx) begin rxstate <= 6'b000111; data[0] <= rxd; end // The sixth tact LSB reg [7:0] data; 6'b000111: if (serclockrx) rxstate <= 6'b001000; 6'b001000: if (serclockrx) rxstate <= 6'b001001; 6'b001001: if (serclockrx) rxstate <= 6'b001010; 6'b001010: if (serclockrx) begin rxstate <= 6'b001011; data[1] <= rxd; end // The 10'th tact 6'b001011: if (serclockrx) rxstate <= 6'b001100; 6'b001100: if (serclockrx) rxstate <= 6'b001101; 6'b001101: if (serclockrx) rxstate <= 6'b001110; 6'b001110: if (serclockrx) begin rxstate <= 6'b001111; data[2] <= rxd; end // The 14'th tact 6'b001111: if (serclockrx) rxstate <= 6'b010000; 6'b010000: if (serclockrx) rxstate <= 6'b010001; 6'b010001: if (serclockrx) rxstate <= 6'b010010; 6'b010010: if (serclockrx) begin rxstate <= 6'b010011; data[3] <= rxd; end // The 18'th tact 6'b010011: if (serclockrx) rxstate <= 6'b010100; 6'b010100: if (serclockrx) rxstate <= 6'b010101; 6'b010101: if (serclockrx) rxstate <= 6'b010110; 6'b010110: if (serclockrx) begin rxstate <= 6'b010111; data[4] <= rxd; end // The 22'nd tact 6'b010111: if (serclockrx) rxstate <= 6'b011000; 6'b011000: if (serclockrx) rxstate <= 6'b011001; 6'b011001: if (serclockrx) rxstate <= 6'b011010; 6'b011010: if (serclockrx) begin rxstate <= 6'b011011; data[5] <= rxd; end // The 26'th tact 6'b011011: if (serclockrx) rxstate <= 6'b011100; 6'b011100: if (serclockrx) rxstate <= 6'b011101; 6'b011101: if (serclockrx) rxstate <= 6'b011110; 6'b011110: if (serclockrx) begin rxstate <= 6'b011111; data[6] <= rxd; end // The 30'th tact 6'b011111: if (serclockrx) rxstate <= 6'b100000; 6'b100000: if (serclockrx) rxstate <= 6'b100001; 6'b100001: if (serclockrx) rxstate <= 6'b100010; 6'b100010: if (serclockrx) begin rxstate <= 6'b100011; data[7] <= rxd; end // The 34'th tact 6'b100011: if (serclockrx) rxstate <= 6'b100100; 6'b100100: if (serclockrx) rxstate <= 6'b100101; 6'b100101: if (serclockrx) rxstate <= 6'b100110; default: rxstate <= 6'b000000; endcase end endmodule There only one problem remained in the whole story - as I have been pressing a key in Putty.exe the module always was sending characters. So is here somebody who could give me a hint how I could program the whole story so that the module sends back only one character? --- Quote End --- Your stop bit is 0. Needs to be 1.
