12 years agoFPGA - PC communication
Hey all, I am trying to get my DE2-115 board and my pc to communicate, but I have no idea where to even start. So far my FPGA training begins and ends with the 10 labs that came with the DE board, pl...
12 years agoHey just try my code - I have programmed the RS232 successfully today:
//******************************************************* //****** PAVLE DUKANOVIC ******* //****** www.dukelanovic.com ******* //****** [email protected] ******* //******************************************************* // Serial port demo program // http://www.techques.com/question/4-13718/implement-serial-port-on-fpga-(verilog) // Assumptions: 50Mhz clock rate module serial(input clk,input key_in, output ser, input rxd); // Start signal tells it to start sending bits reg[24:0]count; reg [3:0] ones; reg [3:0] tens; //The bits of data to send reg [7:0] data; reg sec; reg [14:0] clockdiv; reg [14:0] clockdivrx; // Output register to pin assign ser = outbit; // Count from 0..5207 then reset back to zero (9600 Baud for TX) always @(posedge clk) begin if (clockdiv == 5207) clockdiv <= 0; else clockdiv <= clockdiv + 1; end // Count from 0..5207 then reset back to zero (9600 Baud for TX) always @(posedge clk) begin if (clockdivrx == 1302) clockdivrx <= 0; else clockdivrx <= clockdivrx + 1; end // The serclock is a short pulse each time we are reset wire serclock = (clockdiv == 0); wire start = (clockdiv == 0); wire serclockrx = (clockdivrx == 0); ///////////////////////////////////////////////////////////////////////////// // Serial port state machine // Only start the state machine when "start" is set. Only advance to the // next state when serclock is set. reg [3:0] state; always @(posedge clk) begin case (state) 4'b0000: if (start) state <= 4'b0001; 4'b0001: if (serclock) state <= 4'b0010; // Start bit 4'b0010: if (serclock) state <= 4'b0011; // Bit 0 4'b0011: if (serclock) state <= 4'b0100; // Bit 1 4'b0100: if (serclock) state <= 4'b0101; // Bit 2 4'b0101: if (serclock) state <= 4'b0110; // Bit 3 4'b0110: if (serclock) state <= 4'b0111; // Bit 4 4'b0111: if (serclock) state <= 4'b1000; // Bit 5 4'b1000: if (serclock) state <= 4'b1001; // Bit 6 4'b1001: if (serclock) state <= 4'b1010; // Bit 7 4'b1010: if (serclock) state <= 4'b0000; // Stop bit default: state <= 4'b0000; // Undefined, skip to stop endcase end /////////////////////////////////////////////////////////////////////////////// // Serial port data // Ensure that the serial port has the correct data on it in each state reg outbit; always @(posedge clk) begin case (state) 4'b0000: outbit <= 1; // idle 4'b0001: outbit <= 0; // Start bit 4'b0010: outbit <= data[0]; // Bit 0 4'b0011: outbit <= data[1]; // Bit 1 4'b0100: outbit <= data[2]; // Bit 2 4'b0101: outbit <= data[3]; // Bit 3 4'b0110: outbit <= data[4]; // Bit 4 4'b0111: outbit <= data[5]; // Bit 5 4'b1000: outbit <= data[6]; // Bit 6 4'b1001: outbit <= data[7]; // Bit 7 4'b1010: outbit <= 0; // Stop bit default: outbit <= 1;df // Bad state output idle endcase end reg [7:0] charstate; reg [5:0] rxstate; always @(posedge clk) begin case (rxstate) 6'b000000: if (!rxd) rxstate <= 4'b000001; 6'b000001: if (serclockrx) rxstate <= 6'b000010; 6'b000010: if (serclockrx) rxstate <= 6'b000011; 6'b000011: if (serclockrx) rxstate <= 6'b000100; 6'b000100: if (serclockrx) rxstate <= 6'b000101; 6'b000101: if (serclockrx) rxstate <= 6'b000110; 6'b000110: if (serclockrx) begin rxstate <= 6'b000111; data[0] <= rxd; end // The sixth tact LSB reg [7:0] data; 6'b000111: if (serclockrx) rxstate <= 6'b001000; 6'b001000: if (serclockrx) rxstate <= 6'b001001; 6'b001001: if (serclockrx) rxstate <= 6'b001010; 6'b001010: if (serclockrx) begin rxstate <= 6'b001011; data[1] <= rxd; end // The 10'th tact 6'b001011: if (serclockrx) rxstate <= 6'b001100; 6'b001100: if (serclockrx) rxstate <= 6'b001101; 6'b001101: if (serclockrx) rxstate <= 6'b001110; 6'b001110: if (serclockrx) begin rxstate <= 6'b001111; data[2] <= rxd; end // The 14'th tact 6'b001111: if (serclockrx) rxstate <= 6'b010000; 6'b010000: if (serclockrx) rxstate <= 6'b010001; 6'b010001: if (serclockrx) rxstate <= 6'b010010; 6'b010010: if (serclockrx) begin rxstate <= 6'b010011; data[3] <= rxd; end // The 18'th tact 6'b010011: if (serclockrx) rxstate <= 6'b010100; 6'b010100: if (serclockrx) rxstate <= 6'b010101; 6'b010101: if (serclockrx) rxstate <= 6'b010110; 6'b010110: if (serclockrx) begin rxstate <= 6'b010111; data[4] <= rxd; end // The 22'nd tact 6'b010111: if (serclockrx) rxstate <= 6'b011000; 6'b011000: if (serclockrx) rxstate <= 6'b011001; 6'b011001: if (serclockrx) rxstate <= 6'b011010; 6'b011010: if (serclockrx) begin rxstate <= 6'b011011; data[5] <= rxd; end // The 26'th tact 6'b011011: if (serclockrx) rxstate <= 6'b011100; 6'b011100: if (serclockrx) rxstate <= 6'b011101; 6'b011101: if (serclockrx) rxstate <= 6'b011110; 6'b011110: if (serclockrx) begin rxstate <= 6'b011111; data[6] <= rxd; end // The 30'th tact 6'b011111: if (serclockrx) rxstate <= 6'b100000; 6'b100000: if (serclockrx) rxstate <= 6'b100001; 6'b100001: if (serclockrx) rxstate <= 6'b100010; 6'b100010: if (serclockrx) begin rxstate <= 6'b100011; data[7] <= rxd; end // The 34'th tact 6'b100011: if (serclockrx) rxstate <= 6'b100100; 6'b100100: if (serclockrx) rxstate <= 6'b100101; 6'b100101: if (serclockrx) rxstate <= 6'b100110; default: rxstate <= 6'b000000; endcase end endmodule There only one problem remained in the whole story - as I have been pressing a key in Putty.exe the module always was sending characters. So is here somebody who could give me a hint how I could program the whole story so that the module sends back only one character?
