15 years agoCorrect way to instantiate an SDRAM ?
Hi all,
Got a bit stuck, here, hoping someone can help me out... I'm trying to work through creating a Nios2 system from basics up to something a bit more complex, and the SDRAM is being unreliable. I think I know why, but I don't know how to fix it... Here's the top-level component:
module toplevel (
|* Clock
CLOCK_50, // Input clock @ 50MHz
|* i/o on the board
LEDG, // Green LED bank
KEY, // Pushbuttons
|* SDRAM Interface
DRAM_DQ, // SDRAM Data bus 16 Bits
DRAM_ADDR, // SDRAM Address bus 12 Bits
DRAM_LDQM, // SDRAM Low-byte Data Mask
DRAM_UDQM, // SDRAM High-byte Data Mask
DRAM_WE_N, // SDRAM Write Enable
DRAM_CAS_N, // SDRAM Column Address Strobe
DRAM_RAS_N, // SDRAM Row Address Strobe
DRAM_CS_N, // SDRAM Chip Select
DRAM_BA, // SDRAM Bank Address 0|1
DRAM_CLK, // SDRAM Clock
DRAM_CKE // SDRAM Clock Enable
|* Declare the inputs/outputs direction and widths
input CLOCK_50;
output LEDG;
input KEY;
inout DRAM_DQ;
output DRAM_ADDR;
output DRAM_LDQM;
output DRAM_UDQM;
output DRAM_WE_N;
output DRAM_CAS_N;
output DRAM_RAS_N;
output DRAM_CS_N;
output DRAM_BA;
output DRAM_CLK;
output DRAM_CKE;
|* Set up the GPU system
wire cpuClock, ramClock;
xlgpu gpu
.clk_0 (CLOCK_50),
.cpuClock (cpuClock),
.ramClock (ramClock),
.out_port_from_the_ledg (LEDG),
.reset_n (KEY),
.zs_addr_from_the_sdram_0 (DRAM_ADDR),
.zs_ba_from_the_sdram_0 (DRAM_BA),
.zs_cas_n_from_the_sdram_0 (DRAM_CAS_N),
.zs_cke_from_the_sdram_0 (DRAM_CKE),
.zs_cs_n_from_the_sdram_0 (DRAM_CS_N),
.zs_dq_to_and_from_the_sdram_0 (DRAM_DQ),
.zs_dqm_from_the_sdram_0 ({DRAM_UDQM, DRAM_LDQM}),
.zs_ras_n_from_the_sdram_0 (DRAM_RAS_N),
.zs_we_n_from_the_sdram_0 (DRAM_WE_N)
assign DRAM_CLK = ramClock;
endmodule
... and the system has an on-chip RAM which I'm loading the program into. The code looks like: #include <stdio.h>
int main()
int i;
int mem;
int size=1024;
printf("Input the address to test (hex) : ");
scanf("%x", &mem);
unsigned char *ptr = (unsigned char *)mem;
printf("Starting test\n");
for (i=0; i<size; i++)
printf(".");
*ptr = 0xff;
if (*ptr != 0xff)
printf("address %p failed to read 0xff (%x)\n", ptr, *ptr);
*ptr = 0x00;
if (*ptr != 0)
printf("address %p failed to read 0x00 (%x)\n", ptr, *ptr);
ptr ++;
printf(",");
printf("test complete\n");
return 0;
... and when I type in '0x02000000' (the start of SDRAM) the results in the nios2_terminal look like: http://www.0x0000ff.com/imgs/fpga/commas.png ... where it hangs. I'm assuming there is an exception on read/write to the SDRAM, and the program just dies. The question is, why ? :) Looking at the warning output when creating the system, I see: --- Quote Start --- Warning: PLL "xlgpu:gpu|altpll_0:the_altpll_0|altpll_0_altpll_5pa2:sd1|pll7" output port clk[1] feeds output pin "DRAM_CLK~output" via non-dedicated routing -- jitter performance depends on switching rate of other design elements. Use PLL dedicated clock outputs to ensure jitter performance --- Quote End --- ... so I'm assuming there was too much jitter, the SDRAM didn't respond in time, I got a bus-error, and boom! What I'm not sure of is how to write the verilog that forces the DRAM_CLK output to use the dedicated clock routing. I *thought* I had already done that by setting up the system as in: http://www.0x0000ff.com/imgs/fpga/clocks.png ... where I specifed the c1 output (ramClock) to be -3ns from the cpuClock output. So, I'm not sure what to do at this point... Thanks in advance for any help :) Cheers Simon3 Replies
Ok, replying to my own post... I hadn't altered the 'linker script' in the BSP editor, so the program was being compiled to start in SDRAM, which I was promptly trying to overwrite. Changing the address being tested solved the problem, and let the program finish.
The original question still remains though - how do I get the clock out of the generated system, and onto a pin (DRAM_CLK in this case) using dedicated clock-routing ? Cheers Simon - Altera_Forum
Did you get the pin assigment correct from fpga to sdram clock?
Sean - Altera_Forum
Yep - I'm using the board DE0.qsf file that came with the board, and I haven't redefined any of the DRAM_... or CLOCK_50 lines.
It actually works in hardware - I've run the memtest.c program, and (after realising that both top and bottom of memory are used, one for the heap, one for the stack) I can happily memtest my SDRAM. I'm just curious as to how I *ought* to be doing it so the clock goes by the correct routing. [aside: I can't get DMA to work, but I haven't put too much effort into that yet. Still looking at it :)] Cheers Simon
