15 years agoCorrect way to instantiate an SDRAM ?
Hi all, Got a bit stuck, here, hoping someone can help me out... I'm trying to work through creating a Nios2 system from basics up to something a bit more complex, and the SDRAM is being unrel...
15 years agoOk, replying to my own post... I hadn't altered the 'linker script' in the BSP editor, so the program was being compiled to start in SDRAM, which I was promptly trying to overwrite. Changing the address being tested solved the problem, and let the program finish.
The original question still remains though - how do I get the clock out of the generated system, and onto a pin (DRAM_CLK in this case) using dedicated clock-routing ? Cheers Simon
