15 years agoCorrect way to instantiate an SDRAM ?
Hi all, Got a bit stuck, here, hoping someone can help me out... I'm trying to work through creating a Nios2 system from basics up to something a bit more complex, and the SDRAM is being unrel...
15 years agoYep - I'm using the board DE0.qsf file that came with the board, and I haven't redefined any of the DRAM_... or CLOCK_50 lines.
It actually works in hardware - I've run the memtest.c program, and (after realising that both top and bottom of memory are used, one for the heap, one for the stack) I can happily memtest my SDRAM. I'm just curious as to how I *ought* to be doing it so the clock goes by the correct routing. [aside: I can't get DMA to work, but I haven't put too much effort into that yet. Still looking at it :)] Cheers Simon
