12 years agoAltera Monitor Program Error in Win8
Hi everybody
I'm trying to realize a simple project using Altera Monitor Program on a PC with Win8. but when I'm going to compile the C source I receive the following error. 0 [main] bash 14212 find_fast_cwd: WARNING: Couldn't compute FAST_CWD pointer. Please report this problem to the public mailing list [email protected] Please note that the same project works perfectly on a older PC (with Win7 and maybe with a older release of Altera Monitor Program) Any suggestion ? Thanks in advance15 Replies
Right, problem solved for me. Here is how:
(1) extract the patch into some directory that is not the quartus one. (2) copy the contents of the "bin" folder (not the "bin64" folder) from the extracted files (3) paste this into <quartus directory>\quartus\bin64 replacing any files and folders. For some reason quartus 14 comes with a 32bit version of Cygwin installed in its bin64 directory (I discovered that when trying to use the 64bit Cygwin setup to upgrade it). So basically you have to use the 32bit files to patch it. - Altera_Forum
--- Quote Start --- Probably I've found tyhe solution: I've downloaded the cygwin new release (both the 32 and the 64 bit) and I've used them to substitute the cygwin software delivered with quartus. Moreover remember to include during the installation of cygwin the "perl" utility. --- Quote End --- I return on this old thread because I have exactly the same problem described by marsi but I can't solve it. OS: Win8.1 Quartus 13.1 Original cygwin distributed with Quartus generates a lot of "FAST_CWD pointer" warning messages Updating cygwin eliminates the "FAST_CWD pointer" warning messages, but I'm no more able to download the elf program to Nios. As marsi suggested, I updated both the 32bit and the 64bit parts and installed perl and afaik all other required packages. My current situation is: the project compiles fine, without errors nios2-configure-sof works perfectly nios2-download executes with no apparent error, but it actually does nothing If I launch the Run or Debug in Eclipse I get a generic error message I saved the old installation in \quartus\bin\cygwin_old directory. If I go back to the original cygwin installation by simply renaming it quartus\bin\cygwin I go back to the original situation: I can still download and debug nios project, but I get again FAST_CWD warnings Please help me. I'm really stuck on this point. - Altera_Forum
New Link: http://help.ece.ubc.ca/altera
Details at bottom of page solved it for me. - Altera_Forum
Perfect!
Now it works both for compilation and debugging. The problem was with updating directly from cygwin website, which fixes the compiling problem but somehow corrupts the download/debug features. Thank you! - Altera_Forum
Windows 10, 32bit
Quartus 13.0sp1 worked for me (http://help.ece.ubc.ca/altera): --- Quote Start --- To solve this issue, the Cygwin that is installed with Quartus II must be updated as follows:- Download the patch at ftp://ftp.altera.com/up/pub/cygwin_patch/cygwin_patch.zip
- Extract the contents of cygwin_patch.zip to your Quartus II install directory, overwriting existing files. Both 32-bit and 64-bit versions of Cygwin are included in the zip file; extract both of these versions to your Quartus II install folder. The default path to the Quartus II install folder is “C:\altera\13.1\quartus”.
