12 years agoAltera Monitor Program Error in Win8
Hi everybody I'm trying to realize a simple project using Altera Monitor Program on a PC with Win8. but when I'm going to compile the C source I receive the following error. 0 [main] ...
11 years ago --- Quote Start --- Probably I've found tyhe solution: I've downloaded the cygwin new release (both the 32 and the 64 bit) and I've used them to substitute the cygwin software delivered with quartus. Moreover remember to include during the installation of cygwin the "perl" utility. --- Quote End --- I return on this old thread because I have exactly the same problem described by marsi but I can't solve it. OS: Win8.1 Quartus 13.1 Original cygwin distributed with Quartus generates a lot of "FAST_CWD pointer" warning messages Updating cygwin eliminates the "FAST_CWD pointer" warning messages, but I'm no more able to download the elf program to Nios. As marsi suggested, I updated both the 32bit and the 64bit parts and installed perl and afaik all other required packages. My current situation is: the project compiles fine, without errors nios2-configure-sof works perfectly nios2-download executes with no apparent error, but it actually does nothing If I launch the Run or Debug in Eclipse I get a generic error message I saved the old installation in \quartus\bin\cygwin_old directory. If I go back to the original cygwin installation by simply renaming it quartus\bin\cygwin I go back to the original situation: I can still download and debug nios project, but I get again FAST_CWD warnings Please help me. I'm really stuck on this point.
