12 years agoAltera Monitor Program Error in Win8
Hi everybody I'm trying to realize a simple project using Altera Monitor Program on a PC with Win8. but when I'm going to compile the C source I receive the following error. 0 [main] ...
11 years agoWindows 10, 32bit
Quartus 13.0sp1 worked for me (http://help.ece.ubc.ca/altera): --- Quote Start --- To solve this issue, the Cygwin that is installed with Quartus II must be updated as follows:- Download the patch at ftp://ftp.altera.com/up/pub/cygwin_patch/cygwin_patch.zip
- Extract the contents of cygwin_patch.zip to your Quartus II install directory, overwriting existing files. Both 32-bit and 64-bit versions of Cygwin are included in the zip file; extract both of these versions to your Quartus II install folder. The default path to the Quartus II install folder is “C:\altera\13.1\quartus”.
