Hi
Please let us know whether you are using a custom board
also in the socfpga.dtsi file which you are using whether a cell similar to this is present
rst: rstmgr@ffd05000 {
#reset-cells = <1>;
compatible = "altr,rst-mgr";
reg = <0xffd05000 0x1000>;
altr,modrst-offset = <0x10>;
if yes what is the address mentioned in the cell , is it same like ffd05000 or some thing else.
Also having reserved bits in a register doesn't mean that you cannot read the register. It means that you cannot change those bits or use it for some custom functionality.
Anil
- GGeor256 years ago
Hi Anil,
Before answering your question, one small update. We have SPL enabled and I moved my code in the very beginning of board_init_f:
@@ -306,6 +310,7 @@ void board_init_f(ulong dummy) * First C code to run. Clear fake OCRAM ECC first as SBE * and DBE might triggered during power on */ + reset_cause = readl(&reset_manager_base->status); reg = readl(&sysmgr_regs->eccgrp_ocram); if (reg & SYSMGR_ECC_OCRAM_SERR) writel(SYSMGR_ECC_OCRAM_SERR | SYSMGR_ECC_OCRAM_EN, @@ -316,6 +321,7 @@ void board_init_f(ulong dummy)And I am displaying it later when SPL partition index is printed.
Yes, the board is our design.
The cell in socfpga.dtsi is similar. Our missing "altr,modrst-offset = <0x10>;" and I added it just in case. The address is the same.
--- a/arch/arm/dts/socfpga.dtsi +++ b/arch/arm/dts/socfpga.dtsi @@ -754,6 +754,7 @@ #reset-cells = <1>; compatible = "altr,rst-mgr"; reg = <0xffd05000 0x1000>; + altr,modrst-offset = <0x10>; };I also added in some desperate move in our dtsi the next:
--- a/arch/arm/dts/socfpga_cyclone5.dtsi +++ b/arch/arm/dts/socfpga_cyclone5.dtsi @@ -28,6 +28,10 @@ smplsel = <0>; }; + rstmgr@ffd05000 { + status = <0xffd05000>; + }; +But without success.
Cordially
Georgi
P.S. Do you know how to make warm reset from u-boot. I found one thread here before one year, and the person was complaining the same as me with not custom board. But at least he had warm reset bit read.
