USB Device Issue on Cyclone V / HPS
- 26 days ago
@FabricNS
Please ignore above issue that wasn't it.
I played some more with the tinyusb code and finally found the problem. It seems the old dwc2 USB controller receive fifo size must be set to a minimum of 119 words. The fix is to edit the tinyusb/src/portable/synopsys/dwc2/dcd_dwc2.c file at the function calc_device_grxfsiz().
The original code is:
TU_ATTR_ALWAYS_INLINE static inline uint16_t calc_device_grxfsiz(uint16_t largest_ep_size, uint8_t ep_count) { return (uint16_t)(13 + 1 + 2 * ((largest_ep_size / 4) + 1) + 2 * ep_count); }I changed it to this:
TU_ATTR_ALWAYS_INLINE static inline uint16_t calc_device_grxfsiz(uint16_t largest_ep_size, uint8_t ep_count) { // Altera Cyclone V SoC DWC2 bug, the minimum grzfsiz is 119 words, i.e. 4*119 = 476 bytes #if defined(TUP_USBIP_DWC2_CV) && TU_CHECK_MCU(OPT_MCU_CV) uint16_t words = (uint16_t)(13 + 1 + 2 * ((largest_ep_size / 4) + 1) + 2 * ep_count); if(words < 119) words = 119; return words; #else return (uint16_t)(13 + 1 + 2 * ((largest_ep_size / 4) + 1) + 2 * ep_count); #endif }You will also need to add OPT_MCU_CV into tinyusb/src/common/tusb_mcu.h:
...... //--------------------------------------------------------------------+ // Geehy //--------------------------------------------------------------------+ #elif TU_CHECK_MCU(OPT_MCU_APM32F0XX) #define TUP_USBIP_FSDEV #define TUP_USBIP_FSDEV_APM32 #define CFG_TUSB_FSDEV_PMA_SIZE 1024u //--------------------------------------------------------------------+ // Altera Cyclone V SoC //--------------------------------------------------------------------+ #elif TU_CHECK_MCU(OPT_MCU_CV) #define TUP_USBIP_DWC2 #define TUP_USBIP_DWC2_CV #define TUP_DCD_ENDPOINT_MAX 16 #endifand also ensure to set it in your tusb_config.h:
#ifndef CFG_TUSB_MCU #define CFG_TUSB_MCU OPT_MCU_CV #endif
It seems that the file attachment is not working. You can download the files using the following link:
"USB code" (USB_code.tar.gz) est disponible au téléchargement
Please let me know if you have any issues accessing the files.
- FabriceNs27 days ago
The traffic capture file
- TruHy27 days ago
In HWLIB, you will need to correct the file:
include\soc_cv_av\socal\alt_usb.hIt contains registers with incorrect offset. Search for OFST. The problem starts from this code, so all registers after this:
/* The byte offset of the ALT_USB_HOST_HCFG register from the beginning of the component. */ #define ALT_USB_HOST_HCFG_OFST 0x0The HCFG register should be at offset 0x400, as shown in document: https://docs.altera.com/v/u/resources/r642178/cyclone-v-hps-register-map
- ScottP_Altera27 days ago
I agree that it looks wrong. However, it depends on what passed into ALT_USB_HOST_HCFG_ADDR(). Have you checked the value in a debugger?
