RubenPadial
Contributor
1 year agoUnable to set FAT_SUPPORT when generating preloader with bsp-editor for Arria 10 SoC
Hello, I'm following the Rocketboard guide (https://www.rocketboards.org/foswiki/Documentation/EmbeddedLinuxBeginnerSGuide#2) to familiarize with Embedded Linux development with my Arria10 SoC Dev k...
Jeet14
1 year agoHi,
The shared link https://people.ece.cornell.edu/land/courses/ece5760/DE1_SOC/SoC-FPGA%20Design%20Guide_EPFL.pdf is using the SoCEDS and you need to use the SoC Embedded Design Suite v14.0.
Tiwari
RubenPadial
Contributor
1 year agoHello @Jeet14,
I'm actually using SoC EDS v20 (as mentioned in the first comment). Could you explain the difference between SoC EDS and the SoC Embedded Design Suite? Apparently, they are the same. Is the version a problem? I couldn’t find any version requirements in the Arria 10 documentation: https://www.intel.com/content/www/us/en/docs/programmable/683227/current/installing-the-altera-soc-embedded-development.html
Is there any official guideline for Arria 10?
