binupr
2 years agoUnable to access FPGA_bridge_lwsoc2fpga_2M Address Map from Uboot
Hello there, We are having issues accessing the FPGA LW address map from Uboot. This is for Intel Agilex SoC. Qsys has the LW bridge enabled. We are also enabling this bridge via CONFIG command in U...
- 2 years ago
Hi Binu
So sorry for the late response.
You could use the md command, no need the axi md.
For the example you could take a look at this dtsi.
Jingyang, Teh
binupr
2 years agoHi Jingyang, Teh,
Following up on the above question.
Should we be using 'axi md' or 'md' command in uboot to access AXI light weight bridge?
Binu
