binupr
2 years agoUnable to access FPGA_bridge_lwsoc2fpga_2M Address Map from Uboot
Hello there, We are having issues accessing the FPGA LW address map from Uboot. This is for Intel Agilex SoC. Qsys has the LW bridge enabled. We are also enabling this bridge via CONFIG command in U...
- 2 years ago
Hi Binu
So sorry for the late response.
You could use the md command, no need the axi md.
For the example you could take a look at this dtsi.
Jingyang, Teh
binupr
2 years agoHi,
Can you point from the above link which dtsi are you referring as there are bunch there for different processor target?
The axi command we are using is "axi md 32 0xf9000000"
BPR
