binupr
2 years agoUnable to access FPGA_bridge_lwsoc2fpga_2M Address Map from Uboot
Hello there, We are having issues accessing the FPGA LW address map from Uboot. This is for Intel Agilex SoC. Qsys has the LW bridge enabled. We are also enabling this bridge via CONFIG command in U...
- 2 years ago
Hi Binu
So sorry for the late response.
You could use the md command, no need the axi md.
For the example you could take a look at this dtsi.
Jingyang, Teh
tehjingy_Altera
2 years agoHi
Yeah, the bridges will needed to be added into the device tree as well.
You could refer to our GSRD for the device tree example in the link below:
https://github.com/altera-opensource/u-boot-socfpga/tree/socfpga_v2023.04/arch/arm/dts
What is the axi command that you are referring too?
In uboot you could use the md tool to read through the bridge.
Jingyang, Teh
Jingyang, Teh
