sakthi_iitm
4 years agoSPI interface with Nios II
Please give me example code for Nios II of MAX10 FPGA for making SPI interface.
Nios II SPI (Master ) to be interfaced with slave devices.
I tried this example code in embedded peripheral user g...
ShengN_altera
4 years agoSince I had provided you the solution and did not received any feedback from you, I shall set this case to close pending. If you still need further assistance, you are welcome reopen this case within 20days or open a new case, some one will be right with you.
You will receive a survey. If you think you would rank your support experience less than 10 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
