S10 hps fpga2sdram bridge low speed
Hi Petkov_Alex
Apologies for the slow delay in responding back to your issue. I was looking at this case and just wondering on some of your description on the issue
- Wready is often 0, it means, that slave (axi in this case) is not ready to receive data. Awready is almost times 1.
AWREADY is always high meaning HPS interconnect (or the cache coherency unit) is accepting your write address (queue is empty and waiting for next one)
WREADY is often low/0, means the actual data FIFO in HPS is full, meaning it cannot push the actual data to SDRAM fast enough to cater for the incoming writes, creating some backpressure/bottleneck in the system
I saw there is a KDB on Stratix 10 low memory write but this is on HBM side which supposedly fixed in Quartus 22.2
I will try see any other documentation to see anything related to this case.
- I use constant different address for each bridge, and burst 128 write with 128 bit data, for example 0x20100000, 0x20200000, 0x20300000
So if I understand correctly, it translates into 128 writes * 16bytes = 2048 bytes
Initially i thought might be the 4KB boundary limit but your transaction is within there so no issues as long as its within the boundary.
0x20100000 (bridge 1) , 0x20200000 (bridge 2), 0x20300000 (bridge 3) = gap 1048 bytes (1MB) . Could it be accessing the same bank but different row in parallel thus causing the DDR row thrashing? Just assumption here , possible for you to test spacing the test addresses by 256 MB (e.g., 0x10000000, 0x20000000, 0x30000000) to ensure they naturally hit different banks or bank groups
Kian
- Petkov_Alex5 months ago
Thanks for your answer, I will change spacing and give you result.
- KianHinT_altera4 months ago
Dear Customer,
Since the thread been idling awhile , I will transition this thread to community support.
Altera Technical Support
