ALTERA function fails after execution at C program
- 4 years ago
Hello서박사,
I’m glad that your problem has been fixed.
So I will close this thread if no further questions from you.
Yoshiaki Saito
Hello 서박사,
Thank you for sharing the logs with us.
First of all, you need to confirm Cyclone V SoC register map below.
Cyclone V HPS Register Address Map and Definitions
https://www.intel.com/content/www/us/en/programmable/hps/cyclone-v/hps.html#sfo1418687413697.html
In case of #6, FFD0501C and FFD05020 are valid. But FFD05024 is undefined.
If you access undefined area, AXI bus might response SLVERR or DECERR.
The error will cause Bus Error.
In case of the freezes, could you please try these addresses using 'md' command on U-boot?
If you encounter an error, HPS2FPGA and Lightweight HPS2FPGA bridges might be disabled.
Please check brgmodrst register (0xffd0501c).
The bridges should be enabled on U-Boot.
Yoshiaki Saito
Hello Yoshiaki,
Thank you again for your suggestion.
I've checked the register at the address 0xffd0501c and at the address FF200000 and got the result as follows:
Booting log
U-Boot 2013.01.01 (Oct 12 2016 - 10:40:34)
CPU : Altera SOCFPGA Platform
BOARD : Altera SOCFPGA Cyclone V Board
I2C: ready
DRAM: 1 GiB
MMC: ALTERA DWMMC: 0
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Skipped ethaddr assignment due to invalid EMAC address in EEPROM
Net: mii0
Warning: failed to set MAC address
Hit any key to stop autoboot: 0
SOCFPGA_CYCLONE5 # md.w FFD05020 2
ffd05020: 0000 0000 ....
SOCFPGA_CYCLONE5 # md.w FF200000 1
ff200000:
(freeze)
As far as I know, if the last 3 bit is low (0), the bridges are enabled.
I've also checked that if FPGA itself is not working properly through operating the FPGA in active-serial mode, but I found that the operation of the FPGA is not the issue.
Please let me know if there is any other method to debug this error.
I appreciate your time and effort. Thank you!
- 서박사4 years ago
For your information,
In addition, md command failure log is different between the following u-boot command:
command
run bridge_enable_handoff;
log
## Starting application at 0x3FF795A4 ...
## Application terminated, rc = 0x0before the command, md fails as follows:
command
md.b FF200000 1
log
ff200000:data abort
MAYBE you should read doc/README.arm-unaligned-accesses
pc : [<3ff95052>] lr : [<3ff95027>]
sp : 3ff355b0 ip : 0000001c fp : 00000002
r10: ff200000 r9 : ff200000 r8 : 3ff35f60
r7 : 00000000 r6 : 00000001 r5 : 00000001 r4 : 00000001
r3 : ff200000 r2 : c0000000 r1 : 3ff355bc r0 : 00000009
Flags: Nzcv IRQs on FIQs off Mode SVC_32
Resetting CPU ...resetting ...
U-Boot SPL 2013.01.01 (Oct 12 2016 - 10:38:03)
CLOCK: EOSC1 clock 25000 KHz
CLOCK: EOSC2 clock 25000 KHz(...reboots automatically)
after the command, md fails as follows:
command
md.b FF200000 1
log
ff200000:
(freezes)
Thank you!
