EricOpitz's avatar
EricOpitz
29 days ago
Agilex 5 Multiboot SPL Fails to Probe QSPI
Dear all, I'm trying to activate the RSU Multiboot feature. Unfortunately it seems like the SPL can not probe the QSPI flash. So far I've been able to access QSPI from U-Boot and Linux. My set up:...
  • EricOpitz's avatar
    EricOpitz
    15 days ago
    Dear all,
    I was able to find a solution to this issue. Apparently my defconfig was the culprit as it was based on an older QPDS version. Adding the defconfig entries from the QPDS25.1 solved the problem. The Active Serial Clock speed was not the issue and I left it at the QPDS25.1 default (125 MHz).
    Here are the changes to my defconfig. I don't know which change solved the issue:
    Removed:
    CONFIG_SYS_MALLOC_F_LEN=0x2000
    CONFIG_NR_DRAM_BANKS=1
    CONFIG_ENV_OFFSET=0x04100000
    CONFIG_TARGET_SOCFPGA_AGILEX5_SIMICS=y
    CONFIG_CMD_SF=y
    CONFIG_DOS_PARTITION=y
    CONFIG_SPL_DOS_PARTITION=y
    CONFIG_CMD_NAND=n
    CONFIG_CMD_NAND_TRIMFFS=n
    CONFIG_CMD_NAND_LOCK_UNLOCK=n
    CONFIG_SPL_MTD_SUPPORT=y
    CONFIG_CMD_UBIFS=n
    CONFIG_MTD_UBI=n
    CONFIG_MTD_UBI_WL_THRESHOLD=4096
    CONFIG_MTD_UBI_BEB_LIMIT=20
    CONFIG_ENV_IS_IN_UBI=n
    CONFIG_FPGA_INTEL_PR=y
    CONFIG_MTD=y
    CONFIG_SYS_NAND_U_BOOT_LOCATIONS=n
    CONFIG_UBI_SILENCE_MSG=n
    CONFIG_DM_ETH=y
    CONFIG_UBIFS_SILENCE_MSG=y
    CONFIG_SPL_STACK=0x73000
    CONFIG_MTD_RAW_NAND=n
    CONFIG_SPL_NAND_SUPPORT=n
    CONFIG_SPL_NAND_FRAMEWORK=n
    CONFIG_NAND_BOOT=n
    CONFIG_NAND_DENALI_DT=n
    CONFIG_HUSH_PARSER=y
    CONFIG_SYS_PROMPT_HUSH_PS2="> "
    CONFIG_CMD_FS_GENERIC=y
    CONFIG_CMD_PART=y
    CONFIG_LZO=y
    CONFIG_CMD_DHCP=y
    CONFIG_SPI_FLASH_MACRONIX=y
    CONFIG_SPI_FLASH_GIGADEVICE=y
    CONFIG_SPI_FLASH_WINBOND=y
    CONFIG_SPI_FLASH_ISSI=y
    Added:
    CONFIG_NR_DRAM_BANKS=3
    CONFIG_CMD_NAND_TRIMFFS=y
    CONFIG_CMD_NAND_LOCK_UNLOCK=y
    CONFIG_USE_BOOTFILE=y
    CONFIG_BOOTFILE="kernel.itb"
    CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y
    CONFIG_SPL_MTD=y
    CONFIG_USB_HUB_DEBOUNCE_TIMEOUT=3000
    CONFIG_SPL_STACK=0x71000
    CONFIG_MTD_RAW_NAND=y
    CONFIG_SPL_NAND_SUPPORT=y
    CONFIG_SPL_NAND_FRAMEWORK=y
    CONFIG_BLOBLIST=y
    CONFIG_BLOBLIST_SIZE=0x1000
    CONFIG_BLOBLIST_ADDR=0x72000
    CONFIG_HANDOFF=y
    I took your advice and added some log messages to u-boot:
    - I tested this on the arrow dev kit
    - I used version QPDS25.1
    - I activated multiboot and set QSPI Ownership to HPS
    - I added some debug messages
    From the log you can see that the speed is retrieved from the SDM and this value is used in cadence_spi_probe(). But afterwards there are two more calls to cadence_spi_set_speed() with 100 MHz (probably from dts) and 1 MHz (probably from CONFIG_SF_DEFAULT_SPEED) respectively. Therefore I think the actual speed is 1 MHz. Perhaps you can verify this and adapt the log message "QSPI: Reference clock at 500000 kHz".
    is_ddr_csr_clkgen_locked: ddr csr io96b_0 clkgenA is successfully locked
    io96b_cal_status: Calibration for IO96B instance 0x18400400 done at 0 msec!
    init_mem_cal: Initial DDR calibration IO96B_0 succeed
    DDR: Calibration success
    io96b_mb_init: num_instance 1
    io96b_mb_init: get memory interface IO96B 0
    io96b_mb_init: IO96B 0 mem_interface 0: ip_type_ret: 0x1
    io96b_mb_init: IO96B 0 mem_interface 0: instance_id_ret: 0x0
    io96b_mb_init: IO96B 0: num_mem_interface: 0x1
    LPDDR4: 1024 MiB
    ecc_enable_status: ECC enable status: 0
    DDR: size check success
    DDR: firewall init success
    DDR: init success
    Bloblist at 72000 not found (err=-2)
    WDT: Not starting watchdog@10d00200
    Trying to boot from MMC1
    get_spl_slot
    spi_flash_probe
    CONFIG_SF_DEFAULT_BUS. 0
    CONFIG_SF_DEFAULT_CS. 0
    CONFIG_SF_DEFAULT_SPEED. 1000000
    CONFIG_SF_DEFAULT_MODE. 8195
    cadence_spi_probe
    priv->ref_clk_hz = 500000000
    cadence_spi_probe - return
    hz = 100000000
    cadence_spi_set_speed - return
    hz = 1000000
    RSU current image: 0x01000000
    RSU state: 0x00000000
    RSU error location: 0x00000000
    RSU error details: 0x00000000
    RSU: Partition 'BOOT_INFO' start=0x00000000 length=0x00210000
    RSU: Partition 'FACTORY_IMAGE' start=0x00210000 length=0x00800000
    RSU: Partition 'image1' start=0x01000000 length=0x00800000
    RSU: Partition 'image2' start=0x01800000 length=0x00800000
    RSU: Partition 'SPT0' start=0x00a10000 length=0x00008000
    RSU: Partition 'SPT1' start=0x00a18000 length=0x00008000
    RSU: Partition 'CPB0' start=0x00a20000 length=0x00008000
    RSU: Partition 'CPB1' start=0x00a28000 length=0x00008000
    get_spl_slot - return
    rsu_spl_mmc_filename, filename: u-boot_image1.itb
    spl_mmc_load_image: Boot from filename: u-boot_image1.itb
    spl_load_image_fat: error reading image u-boot_image1.itb, err - -5
    SPL: failed to boot from all boot devices
    ### ERROR ### Please RESET the board ###
    Kind Regards,
    Eric Opitz
