Could you try "bridge disable" before "fpga load" at u-boot prompt?
My understanding is that the configuration error reporting feature is incorporated in v25.1 embedded SW package (need to confirm).
Could you try to compile your FPGA design (GHRD) with Quartus Pro 25.1 and build u-boot from our v25.1 fork?
git clone -b QPDS25.1_REL_GSRD_PR https://github.com/altera-fpga/u-boot-socfpga
As in the Agilex 5 Premium Development Kit Example in https://altera-fpga.github.io/rel-25.1/embedded-designs/agilex-5/e-series/premium/boot-examples/ug-linux-boot-agx5e-premium/#boot-from-sd-card
You would need to include your defconfig (configs/socfpga_agilex5_atuma5_defconfig, include/configs/socfpga_agilex5_atuma5.h) and device trees in arch/arm/dts (socfpga_agilex5_atuma5.dts, socfpga_agilex5_atuma5-u-boot.dtsi).
Stefan
Hi
I have discovered that replacing the line:
.intel_directphy_gts_0_o_rx_parallel_data_o_rx_parallel_data (gts_o_rx_parallel_data)
with
.intel_directphy_gts_0_o_rx_parallel_data_o_rx_parallel_data (32'b0)
Lets the system boot - based on this; what would you recommend?
