Agilex 5 EMAC to EMAC : Driver error
- 1 year ago
Solved: bring MAC signals up a module
The fact that gmac2 works, while gmac0/gmac1 fail with identical setup, strongly suggests-> The reset lines for EMAC0 and EMAC1 are not wired or released correctly in the FPGA handoff.
The Linux kernel attempts to reset the DMA via
resets = <&rst EMAC0_RESET>, <&rst EMAC0_OCP_RESET>;
But these don't actually trigger a reset, leave the DMA in a bad state.
Try a simple test, comment out the resets for gmac0:
// resets = <&rst EMAC0_RESET>, <&rst EMAC0_OCP_RESET>;
// reset-names = "stmmaceth", "stmmaceth-ocp";
Recompile and reboot. If this makes the error go away (or lets the DMA at least initialize), the reset was the issue.
- K6061 year ago
Contributor
Thanks for this suggestion! However it seems that this does not solve the issue. I would be interested to see the rest of the snippet you shared on 06-20-2025. Is that possible?
