Questions about the descriptors of the Modular Scatter - Gather DMA Core
- 1 year ago
Hi Derek,
@Derek_Teng wrote:In the Modular Scatter - Gather DMA Core, when I don't enable the Prefetcher Core, can I write multiple descriptors into the dispatcher FIFO through the Descriptor Agent Port at once? Then, by setting the Go bit in the Control Field of the last descriptor to 1 and starting the DMA transt input in sequence.
You are right.
Yours use case do not required the following prefetcher features, you can don't enable prefetcher.
With Prefetcher enabled, following features are supported:
- Descriptor linked list
- Data transfer to non-contiguous memory space
- Descriptor write back
- Hardware descriptor polling
- 64-bit address spaces
Hi
I will now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Jingyang , Teh
