Questions about mSGDMA
Hi, all!
I'm currently learning how to implement data transfer using mSGDMA and have created a Qsys project for simulation verification. However, the simulation results show that the mSGDMA isn't functioning properly, and I need some assistance.
Below is my system view (with mSGDMA mode set to MM->MM):
During simulation, I performed the following steps:
1. Wrote data to address 0 of mem_s1 (32-bit data width), corresponding to the Avalon-MM address 20'b0.
2. Configured the mSGDMA descriptor with: Read address: 20'b0. Write address: 20'hF0000 (address 0 of mem_s2) .Transfer length: 4 bytes.
However, the data transfer did not occur. Below are the simulation results:
Anpeng
- tehjingy_Altera
Hi
Is it possible if you could share me your project and the steps of running the simulation.
So that I could reproduce it on my end.
Jingyang, Teh
- tehjingy_Altera
Hi
Do you have a follow up on this case?
Jingyang, Teh
- whitepau_altera
Contributor
Hello Anpeng, thanks for posting.
In Chapter 31 of the Embedded Peripherals IP User Guide, there is a section that mentions that you need to commit the descriptor information using the 'go' bit in the control field (bit 127).
31.4.6. Control Field
In your modelsim screenshot, I can see that bit 127 is clear, can you try setting it? - tehjingy_Altera
Hi
Jingyang, Teh
