QSPI read write
- 2 years ago
Hi Oaksys,
Not sure will this help which relates to the dummy cycles, It mentioned that "Third-party quad SPI flash devices may have fixed or configurable dummy clock cycle":
Anyway I will close and transition the thread to community support since the issue has been resolved.
Aik Eu
Hi Oaksys,
I do not understand your write and read operation sequences from your provided examples.
Would like to know if the data error only happened on a specific address only or there is an inconsistency in the write/read process?
For example, everytime you write something, does the written data valid after read?
Or there is data error on specific location whereby the data doesnot change after write which is the 0xF that you noticed?
Make sure to perform erased first before a write and see if any difference.
Aik Eu
