PalaceIsNuclear's avatar
PalaceIsNuclear
3 years ago
Preloader Reset Command Error
I am using ARM DS and the Altera USB-II Blaster to connect to my Cyclone V target board.
When I first connect, I am getting the following error:
ERROR(CMD463):
# in preloader.ds:12 while executing: reset system
! The reset capability system is not available
ERROR(CMD656): The script preloader.ds failed to complete due to an error during execution of the script
My board still connects but does not reset the SW on connection, however, I am able to step through my program with the debugger.
I ran the info capabilities command which returned this section for Reset options (no SW options):
Reset options
Hardware Reset
Available while running=true [Indicates whether System reset is available while running]
What options do I have to restart the SW on connection instead of jumping in at the current point of execution?
  • tehjingy_Altera's avatar
    tehjingy_Altera
    Hi PalaceIsNuclear
    Do you have any update on this case?
    Jingyang, Teh
    tehjingy_Altera
    Hi
    Since there are no feedback for this thread, I shall set this thread to close pending. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
    If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 10 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
    Jingyang, Teh
