Power calculation
From this link (https://www.intel.com/content/www/us/en/programmable/support/support-resources/operation-and-testing/power/max-10-estimator-download.html)
I have downloaded power estimator xlxs sheet to calculate power for max 10 (10M40DA484C8G).
Since sheet is protected I am not able to make changes in it . Beacuse of this we are not able to estimate power correctly.
Please provide the solution.
Kindly find the attached sheet.
Abhilash
- EngWei_O_Intel
Hi Abhilash
May I know which cell you are trying to edit? Certain cells are meant for results generation purpose.
Eng Wei
- abhilash
I am attaching the file in which I am using.
In IO sheet you can see below there is a table in which we can enter voltage in IO standard column, I am not able to select 1.0 v. Since we are using IO pins at 1V so it is required to calculate power at that voltage.
Could you please provide us the solution?
- EngWei_O_Intel
Hi Abhilash
If we referring to Table 20 and Table 21 in the doc https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/m10_datasheet.pdf
Certain I/O standard only available for certain devices of Max10. I can see 1.0V is available if let's say I am choosing Device 10M08SC, package U324.
Eng Wei
- abhilash
Hi Wei,
Below table 20 it is mentioned that device 10M40DAF484C8G supports 1V.
Could you please tell me if there is any way to choose 1V because I am not able to choose it for this device.
Abhilash
