Power calculation
I am attaching the file in which I am using.
In IO sheet you can see below there is a table in which we can enter voltage in IO standard column, I am not able to select 1.0 v. Since we are using IO pins at 1V so it is required to calculate power at that voltage.
Could you please provide us the solution?
Hi Abhilash
If we referring to Table 20 and Table 21 in the doc https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/m10_datasheet.pdf
Certain I/O standard only available for certain devices of Max10. I can see 1.0V is available if let's say I am choosing Device 10M08SC, package U324.
Eng Wei
- abhilash6 years ago
Hi Wei,
Below table 20 it is mentioned that device 10M40DAF484C8G supports 1V.
Could you please tell me if there is any way to choose 1V because I am not able to choose it for this device.
Abhilash
- EngWei_O_Intel6 years ago
Hi Abhilash
Let me check with the tools team before getting back to you.
Eng Wei
Hi Abhilash
We are still working with Engineering team to take a look on this. Will keep you posted once there is any update.
Eng Wei
